Hello, newbie here and thank you all very much in advance.
I have two 8’ electric baseboard heaters in my living room. Both are on the same breaker and both are controlled by one old Honeywell T87F low voltage thermostat and a White-Rogers relay box in the basement. One of the heaters will not turn off even when the temp is lowered all the way on the thermostat. The other heater operates normally. Logic (?) tells me that the problem has to be the relay and not the thermostat. Am I on the right track in trouble shooting this? Any thoughts and/or suggestions would be very appreciated. Thanks a lot.
