hi, problem with baxi solo boiler. lockout lit. burner led and mains led flashing. the legend on the flap says this indicates no water flow. was working fine till i had to turn off the hot water at the hot water tank to fix a blown joint . now it's locked out. pressing the reset just leaves the mains led on it won't fire up and after a few mins goes back to lockout
