help with dilog tester | on ElectriciansForums
Discuss help with dilog tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sima24
Hi all, i got a dilog 9083p tester a few weeks ago. Its been brilliant, but yesterday i was doin a zs test from living room light and everytime i pressed the test button it beeped and the screen jist displayed "fuse". Do zs test on the dining room light and gave me a good reading, so i know its not the actual fuse. Anyone had this happen or know what the cause could be?
Thanks in advance
Try cleaning the fuse end caps and fuse holder contacts with isopropyl alcohol or switch cleaner, if they are badly tarnished use a mild abrasive first, if this intermittent condition persists fit a new fuse.
Reply to help with dilog tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, Do you have the user guide. If not I will put the link at the end of the mail. May be worth checking that the meter has been set for UK usage...
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
