E
EndlessHysteria
Hi all,
To be clear I am still new to the job and this is the first time I've dealt with this situation.
I'm installing LED panel lights in a suspended ceiling, I've used dimmable drivers connected to the switched live and neutral on the input. And live and neutral on the output.
I've replaced the existing switches with rocker switch dimmers connected to permanent live and switched live.
Problem I'm having is that when the switch is pressed the light activates, however when the switch is releases and rocks back the light turns off.
Please any advice would be welcome as I've not dealt with dimmable LED panel lights before and I know I've still got a lot to learn in the trade
