Help with discrimination | Page 2 | on ElectriciansForums
Discuss Help with discrimination in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
All enclosures of RCDs or consumer units incorporating RCDs in TT installations should have an all-insulated or class 2 construction, or additional precautions, as recommended by the manufacturer, need to be taken to prevent faults to earth on the supply side of the upstream 100mA, S type, RCD.
That's why we're suggesting a 'front end' RCD.
If its a large installation you could go with a 300 mA time delayed, the front end RCD sees everything, capacitance, resistive leakage, appliance leakage etc, if the 100 trips first it may be because its already near its threshold?
Reply to Help with discrimination in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
