Help with earthing circuit | on ElectriciansForums
Discuss Help with earthing circuit in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hi everyone
I'm a DIYer with little electrical knowledge looking for some advice I'm currently building a sterilisation cabinet with a UVC light in it. The cabinet is a Wooden box with a hinged lid I plan to use a microswitch to cut the uv lamp when the lid is opened.
Am I correct to think I can have a power lead coming in to a connecter block, take the + wire to the microswitch and back to the connector block and then take all wires + - and earth from connector block to the ballast unit? With the earth then connect to the ballast? Or would I need some special arrangement to earth it? The ballast unit will be mounted on the box and the earth will connect to an earth port on the ballast unit would this be sufficient to ground the circuit? See sketch.
All help much appreciated!
[ElectriciansForums.net] Help with earthing circuit
The mains is AC, there is no positive or negative. There are line and neutral, a single-pole switch breaks only the line. If the interlock microswitch is a safety device, your risk assessment should indicate whether a single or double-pole interlock is needed, and whether the switch needs special characteristics such as guided contacts to ensure the requirements for safety are met. If not, and it is merely functional switching, a single-pole switch is fine and preferable.
Generally it looks OK, but it is a bit odd having the "safety" switch as the main functional switching part. In this case though I guess you are really just making sure no one gets UVC in their eyes.
How do you time it for sufficient sterilisation? It might make sense to look at adding some sort of timer as well so you can set 5min (or whatever) and forget about it.
You mentioned it is made of wood so other than the ballast I presume there is no metal with any risk of getting close to a live wire to be earthed?
Finally make sure all the terminals are properly boxed / shrouded so there is not possible risk of touching them, and also think if there is any water or other liquid involved that would present a risk of getting in to the switch.
Wago make plastic boxes and various matching terminal blocks for joining stuff you might want to look at using, but if it is inside a box without risk of contact then standard screw 'terminal strip' joints can be used. Just don't forget to secure the main cable mechanically to the overall box before the outer sheath is removed and it reaches the terminals.
Thanks for your feedback my Initial plan was to just switch it on and off at the mains and the microswitch just to prevent accidental exposure but Timer is a great idea.
The only metal are some brackets on the exterior. Should I earth these? I plan to use terminal blocks to house the connections so they aren't exposed the ones I'd seen were from screwfix.
You only need to earth the external metal if it is possible it could become live under fault conditions. Realistically if it is a wooden box, your wires are all several cm away, adequately insulated themselves, and clipped in place, that would be 'no'.
It's quite severe, soon get that burnt pork smell when skin is exposed, even for a few seconds. It also spews out what I can only assume are hazardous amounts of Ozone. At least it comes with the original safety goggles... Most vintage medical stuff just seems to make your health worse.
yrears ago i remember we had a tanning lamp, 1 element for warmth, and the UV was generated by a carbon arc. you screwed the electrodes together till they shorted, then screwed them back a bit to get a good sizzling arc. doubt it could get a CE mark nowad
ays. it was bloody lethal.
OK thanks for the advice. I now plan to use 2 microswitch for the lid for extra security and a timer switch so the unit automatically switch off after certain elapsed time say 10 min. One more question does only the live wire feed to the switch or does the switches need live and earth? I want to use single pole micro switch.
This is my new sketch diagram
Reply to Help with earthing circuit in the UK Electrical Forum area at ElectriciansForums.net
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
