Help with earthing circuit | Page 2 | on ElectriciansForums
Discuss Help with earthing circuit in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hi everyone
I'm a DIYer with little electrical knowledge looking for some advice I'm currently building a sterilisation cabinet with a UVC light in it. The cabinet is a Wooden box with a hinged lid I plan to use a microswitch to cut the uv lamp when the lid is opened.
Am I correct to think I can have a power lead coming in to a connecter block, take the + wire to the microswitch and back to the connector block and then take all wires + - and earth from connector block to the ballast unit? With the earth then connect to the ballast? Or would I need some special arrangement to earth it? The ballast unit will be mounted on the box and the earth will connect to an earth port on the ballast unit would this be sufficient to ground the circuit? See sketch.
All help much appreciated!
[ElectriciansForums.net] Help with earthing circuit
OK thanks for the advice. I now plan to use 2 microswitch for the lid for extra security and a timer switch so the unit automatically switch off after certain elapsed time say 10 min. One more question does only the live wire feed to the switch or does the switches need live and earth? I want to use single pole micro switch.
For functional switching it is perfectly normal to only switch the phase (live) conductor, but that is not providing isolation that would be needed for any work on the unit such as replacing the UV tube.
If you are building this just for yourself to use that is probably OK, but it is always a good idea to put a warning on if others might ever try to use it to the effect that you must switch off and unplug it before replacing the tube. The "others" who are unaware of the limitations of the switching might be you in 10 years time!
Looks ok, make sure all the terminals are insulated.
yrears ago i remember we had a tanning lamp, 1 element for warmth, and the UV was generated by a carbon arc. you screwed the electrodes together till they shorted, then screwed them back a bit to get a good sizzling arc. doubt it could get a CE mark nowad
ays. it was bloody lethal.
I have one of those, I did wonder if it ever had a guard, mine is missing. The element is mostly to act as a resistor as the arc is basically a short circuit. The adjustment knobs have exposed live parts, and the little metal plate at the bottom only stops some of the carbon sparks from going on the carpet. And it's best not to mention the asbestos the element is wound on.
View: https://youtu.be/GhmhX4Bne30
those switches don't need earthing, but each cable needs an earth conductor and the earth must be continuouse. i.e. connect the in and out with a connector art the switch position/s.
What do you mean earth conductor?
The earth conductor from the 13A plug to the ballast, etc, for protection.
I think Telectrix means is it should not have any joints that could come loose, such as screw terminals, etc, as that presents an additional hazard. Of course a lot of equipment has the earth cable in to a screw terminal when it enters the equipment, but that is another story...
Ways of joining that are considered permanent (i.e. making two wires in to an "continuous conductor") include soldering and crimping, assuming either is done competently. Some of the spring loaded joints (e.g. Wago) are considered "maintenance free" as they do not loosen with vibration or thermal cycling, so that is another way.
But the original (and some say best) is to use a wire where you strip a bit of insulation mid-way, and bend that in to a protruding conductor that can then be screwed in, etc. That way is the screw comes loose you disconnect from the terminal (as expected) but the downstream joints are still properly earthed. (Can't find a picture just now to show this, maybe someone else can?)
Reply to Help with earthing circuit in the UK Electrical Forum area at ElectriciansForums.net
I'd always go for 25mm2 5core over 50mm2 3core, with the cores paired up. Considerably cheaper, easier to terminate and ready to go, if ever 3...
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
