Some help I have a glow worm 24c and I am trying to install a hive System coming out of the glow worm 4 wire L-N-E and black so I have wired L-N-E correctly and the back in terminal 3 the receiver is all works and both green lights but the boiler is not kicking in do I need to bridge the common and 1
Yes luckily I found the Old manual and I did speak to the company who made the old controller to see if terminal 2 was 240-volt and they said with the bridge it would be so I know no it won't damage the motherboard
I probably should have been clearer, I've got a different boiler and it has more connections I just assumed most boilers would be the same in terms of the thermostat connection
No they are not all the same, and you shouldn't make assumptions when advising someone on how to connect something.
Preston
United Kingdom
Help with hive installation
Twinny,
davesparks,
