Hi, I am trying to install this bathroom fan timer switch: Amazon.ca - https://www.amazon.ca/dp/B0764KXMHP
We have a 3-way switch with the fan on the right end. The wire covers both look the same colour, and I can see a white wire behind that isn't connected to any switch.
Question 1: I'm guessing the white wire is the Neutral wire?
Question 2: Can someone confirm which wire going into the switch is which? It looks to me like the bottom wire is the ground.
Question 3: How should I connect the new switch timer?
I've attached images that I hope help, if another pic would be helpful please ask and I will upload more. Thank you kindly for any help!
Canada
Canada
Help with installing bathroom fan timer switch
DIY Electrical Advice
Thread Tags
Tags Tags
None
furrykitten,
