HELP !! with Insulation resistance test on ring and lighting circuit | Page 2 | on ElectriciansForums
Discuss HELP !! with Insulation resistance test on ring and lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
if L&N are linked, you can test to E at 500v
for the continunity of cpc (lighting) the furthest point,and do the test,but if you have two way at the stair,one switct up and one down,does that count as the furthiest point?
With lighting circuits, in fact with any radial, it is not always apparent which is the furthest point.
As such an R1 + R2, or Zs test at each point will determine this. Doing such will also determine correct polarity of switches.
Any switches that do not affect the readings will show reversed polarity.
i would identify the furthes point by the fact that there was only a feed in & switch wire . ( assuming loop-in at fitting scenario)
Not always possible, if for instance a spider configuration is used, or with spurs.
Also where there is two way switching, or even two way and intermediate switching some lights whislt physicaly closer to the CU, may in fact have higher R1 + R2/Zs values than fittings further away.
agreed if spider or spurs, but in a standard loop in lighting radial ( talking mainly domestic ) the furthest point will be the one without a feed going out from the fitting, irrespective of how physically close to the CU it is.
Good point, because that is the answer i was waiting for, i have a two way switch and the reading is highter than the furthest point,
Reply to HELP !! with Insulation resistance test on ring and lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
