Help with insulation resistance testing on a lighting circuit | Page 3 | on ElectriciansForums
Discuss Help with insulation resistance testing on a lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
bit late to this party but L-E IR test should not be impacted by a bulb present. L-N will impact if a bulb is present and the reading will be low.
If you cannot isolate everything and there are sensitive equipment then connect L-N together and just do IR across E and L-N connected together. If the reading is above 1m then ok but if low further investigation is required.
very good explaination
thanke much
Reply to Help with insulation resistance testing on a lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
