OP
How old is that 400w dimmer? Varilight don't seem to do them anymore.
Got it from screxfix on friday
Discuss Help with LED Dimming in the The Welcome Forum area at ElectriciansForums.net
Agree with this, 12 watt load on a 400 watt dimmer is insufficient and making the output stage unstable especially at low dimming levels. I'd also go with a 50 or maximum a 100 watt dimmer.
Yes I believe switching to a lower wattage dimmer worked because it had a lower minimum loadI changed it for a LAP 100w dimmer switch and it’s fine now! Found out that my neighbours light isn’t dimmable which explains that too!
Reply to Help with LED Dimming in the The Welcome Forum area at ElectriciansForums.net
