Help with led problem! | Page 2 | on ElectriciansForums
Discuss Help with led problem! in the UK Electrical Forum area at ElectriciansForums.net
hoppy
Liverpool
Hi
I have been to replace 2 bathroom wall lights from mr16 to 2 new led lights, however due to wiring issues, I have had to put the transformers in the loft. The lights will not
work and I believe it is due the the length of the existing 12v cables and the fact the new led lights do not draw enough current to make them
work. When I put my voltage testers across one of the transformers in the loft, the light it feeds works.
is there anything I can get to make these lights work, and would I fit it at the transformer or the fitting itself?
thanks
craig
I don't think so, I would say I have more of an ability to refrain from posting on threads when I don't know the answers, which makes me appear more knowledgeable than people who post up guesses and wrong answers
Haha! Yeah defo a good policy to keep quiet sometimes. However your electrical knowledge, along with numerous other members on here, is excellent, and just shows how complicated electrics can be in my view. When I first started the CG 2330 approx 11 years ago, I never anticipated that the breadth and depth of electrical theory/practical work would keep me feeling like I know very little still! That is partly why I find forums like this can be fascinating.
Hi, sorry, been mad busy!
thanks for the replies.
the cables from the loft are a 2 core aluminium or steel conductor with a clear sheath, I wouldn't want to put 230 down them.
the new lights have built in drivers, but as I didn't want to put 230 down the existing cables, I took the drivers out of the fitting and located them in the loft! There are each light is wired separately from the loft, and each has its own driver. The first lights cables are about 800mm long and the second lights cables are about 1500mm long.
my voltage tester is a megger.
thanks
craig
thanks
craig
Do you think you could repost this when you have sobered up?
Would it make you feel better or worse to know that I started the 2330 (and consequently my apprenticeship) at around the same time?
thanks
craig
So you took the fitting apart and put a longer cable between the driver and LED than it was designed to have?
It could be that the added impedance of the cable is the problem.
Or the fact they come on when you apply the test probes could mean the terminations are loose and only make good contact when pressure is applied.
Reply to Help with led problem! in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
