Help with lightbulb fitting | on ElectriciansForums
Discuss Help with lightbulb fitting in the Lighting Forum area at ElectriciansForums.net
Visar
London
Hi guys,
Earlier today I was trying to adjust the components - images attached in order to put the new shade I just purchased but as I was unscrewing it broke off. Please could someone shed some light on what I can do, possibly order so I can carry this out. My guess is that these components were old/cheap hence why it happened I mean they were so fragile.
Many thanks!
[ElectriciansForums.net] Help with lightbulb fitting
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Naah, you've gotta be standing on a pair of steps or a chair fiddling around with that, go with gutterball's original plan (as revised by 123), easier when balancing on a pile of books. :)
As advised above, agree you should isolate the power at the main fusebox/consumer unit.
Changing the lampholder only is possible, but maybe a little fiddly. 123's suggestion is good if you're not comfortable going into the ceiling rose part.
Whichever way you choose, remember to thread the flex through the hole in the cover of the rose or the lampholder before connecting up.
Reply to Help with lightbulb fitting in the Lighting Forum area at ElectriciansForums.net
I use theses very regularly doing 12 monthly DB inspections, a great bit of kit and easy to use
