Help with motor | on ElectriciansForums
Discuss Help with motor in the Talk Electrician area at ElectriciansForums.net
Brighton
Hello people
i I need some help with motor connections I need to replace a tyre machine motor, I have the new motor but it's not quite the same I have a 4 pole 1hp motor cap/run/start the wiring on it shows how to wire in two opposite directions problem I have is you can only choose one or the other by moving links but I need both directions
its supplied from a foot peddle with a switch on push down for one direction up for the opposite with a separate lines for each
is there any way of making this work thanks
Reply to Help with motor in the Talk Electrician area at ElectriciansForums.net
Well at about 9.30 last night I stripped the door card off and found the culprit, cable snapped and end off. So I spent another hour and managed...
    • Funny
I'm glad that in my car, if i want to move the steering wheel, I just use a lever on the side of the column...
