R
rich67577
right this is a strange on there are gu10 lamps fitted at present on a 40watt dimmer switch so i changed lamps over to the newlwc high powerd led ones wich are 3x2watt did it with 2 wich worked fine but when i changed all 4 over it blew 2 lamps up and also blew up the40watt dimmer swich wich semas strange as these are direct replacment for the gu10 and only 6 watt each so should work fine on a 400watt dimmer switch and semas strange that the lamps also blew up on me and the lamps are not cheap either the retail at £65.00 each
