Help with noises please | Page 2 | on ElectriciansForums
Discuss Help with noises please in the UK Electrical Forum area at ElectriciansForums.net
I am going to put another vote in for a shower pump.
where in the West Midlands are you?
I may be able to pop in and clear this up for a beer if you are nearby.
sure it’s not the shower pump as you couldn’t hear it in the garage from where the shower is at the rear off the house but your welcome to call in if your passing and I’m more Staffordshire burntwood
As well as the MCBs being installed upside down (who would do that?) There is also single insulated wires visible above the enclosure.
I would definitely recommend having the wiring inspected and tested throughout!
If its not a pump it could be a loose connection arcing. What rating is the shower? The impulse LED is flashing quite fast!
Reply to Help with noises please in the UK Electrical Forum area at ElectriciansForums.net
https://www.edwardes.co.uk/products/mk-k1257whi-logic-plus-1gang-13amp-non-standard-dp-switch-socket?gad_source=1&gclid=EAIaIQobChMI7POp_pHFhgMVk5J...
Thank you for the suggestion!
