help with problem radial circuit pls ?? | Page 2 | on ElectriciansForums
Discuss help with problem radial circuit pls ?? in the UK Electrical Forum area at ElectriciansForums.net
F
fixit4u
Hi folks,
called out to my aunts house couple of days ago saying she has lost power to her sockets, , upon arrival found the db was a split board and the rcd had tripped the sockets out, i turned all the breakers off and the rcd now stayed on, i turned them back on one at a time until the radial circuit feeding the conservatory tripped the rcd again, i took the fronts of the sockets all seem to be ok, connections tight etc and all connected together,so i took all the sockets of the wiring and connected the first one , no trip, secong one same and also the last socket -3 in total, strange all seem ok now i thought, so i fastened the first one back to the wall-trips again, take off wall now ok ??? any help please, i put the socket on and moved the wires to the side this time and all ok, two days later tripping back again ????? :mad2:
Reply to help with problem radial circuit pls ?? in the UK Electrical Forum area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
Which rcd is it? Is it one for everything, one for a few circuits?
