Hi guys & girls I come across this forum whilst searching for help on the solar I boost. I have moved into a new build flat that has this system to heat the water, problem is none of us oldies really know how it works, well I sort of get it but getting conflicting answers, so if anyone could help I would be internally grateful
We have solar I boost+ and eco mega flow cylinder.
I am assuming the timed sessions twice a day are being run by mains electricity (paid for) or if enough solar power it will use that? I am assuming the same for manual boost, but have been told this manual boost only comes from mains electricity (paid for)? Between the morning timed session and the evening timed session it will pull from only the solar as and when needed if enough there but will not pull from mains electricity? So if we toggle and turn off all timed sessions will it just pull from solar as and if there is enough generated? Or does it have to have some timed sessions? Bit confused as the timed sessions, one is early in the morning before the sun is even out. if so what are we best doing, are heating is electric so costing a lot and we obviously don’t want to be paying for hot water if we don’t need to be or because our timers are all to pot, thank you for reading on behalf of me and another 21 tenants
