Help with supply info and certification info for a flat... | on ElectriciansForums
Discuss Help with supply info and certification info for a flat... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys, im new to this forum so go easy please ;)
I am 17Th Ed and Part P Accredited. Have been doing electrical work for years ( commercial, minor works only ) but I havent done any house bashing for years ( about 9 or 10! ). I am not part of a scheme as my employer doesnt need it. Im an MOD SUBBY doing mainly minor works or the occasional new circuit /ring final/ lighting. ( sounds like an easy life doesnt it LOL).
I have contacted the LBC and thay are happy for me to do the work on production of my 17Th Ed certs (C&G) and a fat wad of over ÂŁ100 to come and inspect! (Still chaeper than a scheme as I dont inted doing another house bash EVER!)
Anyways. I have bought my daughter a flat and it needs gutting and, needless to say, the wiring needs upgrading. So, full rer-wire and new C/Us ( one for main supply and one for economy 7 night storage). The economy 7 was a simple 4 way board and RCBO on all circuits ( just for piece of mind ). The main board is an twin RCD and MCBs to suit each circuit.
That is 90% finished and my mind is looking to the certification and BOY am I rusty! Ok thats out of the way, cut to the chase...
I have been in the supply/meter room (seperate room, were talking 13 floors up!). Its full of trunking and about 20 or so meters, one of which is mine. Luckily there is a double pole breaker inline so I didnt need to pull the fuse ( the seal has long since gone anyway ).
The first thought is supply info ( there may be more questions looming, but as I am only there weekends ....)
THERE IS NO WAY OF SEEING THE MAIN INCOMING SUPPLY TO DETERMIN THE SUPLY TYPE IE. TNC OR TNCS (VERY unlikely top be TT!). ALL I HAVE IS A CONDUIT INTO THE FLAT WITH l/n/e SUPPLIES AND 2 SMALLER CONTROL WIRES FOR THE NIGHT ECON'7 GEAR.
Is there a general *rule of thumb/ standard accepted practice* for supplies to flats guys? I have rung the provider and they have no records ( sounds familiar?? ).
Im confident with the design/ practical side, but the report looks unfamiliar and Im VERY anxious to get it right with the BCO when he calls!
So guys, can you offer any help please?
Reply to Help with supply info and certification info for a flat... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
NICEIC Certification Scheme NICEIC Competant person scheme
This sounds very similar to me. My level 3 NVQ is in engineering maintenance and I also have a HNC in Operations Engineering. I’ve been working...
