Help with wiring up a contactor and stop switch to a VFD | Page 2 | on ElectriciansForums
Discuss Help with wiring up a contactor and stop switch to a VFD in the UK Electrical Forum area at ElectriciansForums.net
UK
Morning, I'm building a small control panel for a VFD, The VFD has 24v lines for motor run and stop, these use a momentary switch. The stop button provides a braking function for the motor through the VFD.
I want to connect a contactor between the VFD and motor to safely isolate the motor. I could use a separate switch to disconnect the contactor, but it would be nice to use the same momentary switches as run and stop. There would have to be a delay on the stop button to allow the VFD to brake the motor.
Is this possible?
Reply to Help with wiring up a contactor and stop switch to a VFD in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
The point is that you set up a schedule of what temperature you want at what time and the nest brings the heating on at the right time to achieve...
davesparks
