Henry has died | on ElectriciansForums
Discuss Henry has died in the Australia area at ElectriciansForums.net
Sanke
Hi guys
My trusty Henry Vacumn has died & just wondered what the forum thinks are the best
Wet n dry ?
Just dry ?
What makes ?
Hi guys
Wasnt looking for consumer advice just wondered what people thought was good.
Need vacumn to clear up plaster etc from chases & drill holes. Have had a Henry which was good but only used for dry stuff. Been looking around and seen Dewalt Karcher etc but wasnt sure iof worth the money
theres all sorts of stuff about but it either aint got the guts or its top heavy and keeps falling about all over the place or summat like that.....have to look hard now to find owt decent......with a lot of things though is this now.......
Reply to Henry has died in the Australia area at ElectriciansForums.net
First question: how old are you? If you're under 46 then you're eligible for a sponsored visa. If you're older than that, then this is an...
You could compare the resistance of the coil of each (e.g. using a multimeter - though with the relays in circuit with their drivers you might get...
