Henry has died | Page 2 | on ElectriciansForums
Discuss Henry has died in the Australia area at ElectriciansForums.net
Sanke
Hi guys
My trusty Henry Vacumn has died & just wondered what the forum thinks are the best
Wet n dry ?
Just dry ?
What makes ?
I would go with the Earlex as someone has said above. Mine was in fact was branded as Wickes but the same thing. Don't think Wickes do them anymore. It has taken some serious abuse - from rubble to sawdust to draining a flooded extension. You can get the same thing from tlc-direct part number EX-WD1000 and they have just cut the price to ÂŁ50. Mainly use mine with the wet n dry filter in place all the time and you can just hose the filter clean. I did buy some cheapo filters off eBay and they were rubbish but the tlc spares are fine.
Reply to Henry has died in the Australia area at ElectriciansForums.net
J
Exterior grouting with the wet weather. Hi, I've laid an external porcelain patio on a sand and cement bed with ultrascape priming slurry. It...
Jed2009
J
First question: how old are you? If you're under 46 then you're eligible for a sponsored visa. If you're older than that, then this is an...
