Here's one for the motor fans! | on ElectriciansForums
Guest viewing is limited
Discuss Here's one for the motor fans! in the Commercial Electrical Advice area at ElectriciansForums.net
High Tower
Nearly Esteemed
Birmingham
Ok, so 10 points to the first person who can tell me what this lot is and what it does............
  • [ElectriciansForums.net] Here's one for the motor fans!
It is an electrical installation and it has coordinated characteristics to fulfill specific purposes to run items for the generation, conversion, transmission, distribution or ultilisation of electrical energy!!
Water pumps with slip ring motors, liquid starters to the side of the motor. There are also vent valves to the top of the casing.
yes agree des i was thinking same area but maybe cargo doors etc but whatever they are closing or opening it looks like a set of hydraulic pumps.
But il put my guess at hydraulic system for a bridge that opens or swings to let shipping through.
Ok tony was spot on with what equipment it was, and a few were close with the use. They are three pumps which are used to empty .........this, it's the dry dock that titanic was fitted out in, these three pumps were originally steam powered and could empty the 20000000 gallon dock in 90 mins. It's in the old harland and Wolff yard in Belfast and the pump house is the building in the top of the shot.
Reply to Here's one for the motor fans! in the Commercial Electrical Advice area at ElectriciansForums.net
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
Do you have a test meter of any kind? if so, disconnect all four wires that go into the motor and check for a low resistance between them. You...
Recommended Sponsor News
Hi everyone,
