[TABLE="width: 598"]
[TR]
[TD]1. 24k BTU Split type Aircon – 12.2Amp, 2,730Watts
[/TD]
[TD]Watt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2. UPS 10KVA 3Phase 230V[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]3. Motion Sensor and Access Control[/TD]
[TD]20[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4. Fire Alarm/Siren[/TD]
[TD]30[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]5. Lights (8pcs)[/TD]
[TD]144[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]6. Emergency lights[/TD]
[TD]500[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]7. Client Equipment[/TD]
[TD]300[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]8. Electrical Outlet – 6 pcs[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]TOTAL LOAD[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
We have been tasked by a client over here to design a PV system for several remote sights over here that will be used for Antenna Masts. So I'm dealing with Americans which is always bad news.
So I have been sent the above specs from them and going over it seems quite straight forward. I have recommended that instead of the 24,000 BTU unit for a cubicle the size of which is Approximate dimension: 5.5m x 2.5m x 2.5m, so a little excessive, that we utilize Evaporation cooling. As the sites are visited weekly water should not be a problem
Now the PV side on that load should be about 1.5KW so not too bad and I have sourced something like this website but it's from the States. Does any of our PV lads know an equivalent from the UK we must do one and can link me to it please
Off-Grid Photovoltaic Systems
But what is getting me is the UPS 3 phase 10KVA for what would be a single phase 1.5KW supply if they use evaporated cooling. They have accepted the cooling option but still insist on the 10kVA UPS .................no talking to some
What I would like to throw out here again to the PV lads, Because the cubicle is 24/7 obviously we will need batteries for the night/early morning. So every day for a few milli-seconds we will get a situation where there is power interruption from PV-Baterry_PV and I would imagine the UPS would want to kick in. Can you see any conflict with the inverter/charger on the PV and the inverter on the UPS. I can see some sort of conflict but can't prove it as such
[TR]
[/TD]
[TD]Watt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]144[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]500[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]300[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]TOTAL LOAD[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
