View the thread, titled "Hi everyone, new to the Forum, no electrical knowledge" which is posted in UK Electrical Forum on Electricians Forums.
Hello everyone, I'm a new homeowner member and would be really grateful for some advice as I know virtually nothing about electrics. My question/worry involves two single ovens I've just had fitted that the electrician has plugged into a double socket. There is also an isolation switch fitted in the cupboard. I have read that a double socket is good for 20 amps, these two ovens are 2.85kw each and are fitted with 13 amp plugs. Doesn't this add up to 26 amps being used if both ovens are on at the same time? Isn't that a potential fire hazard? Previously in the same place was a slot in double oven cooker wired in with a thick cable. I have also had an induction hob fitted and that has been wired in. I have mentioned my worries to the electrician who tried to explain things to me (went over my head) and ultimately said a double socket is fine. But I'm still unsure and it's niggling me.
I've attached a photo. Any help would be appreciated. Thankyou
You know not all over sixties are able to retain their wet pants........
cos.......I'm pishing meself!!!!!!?
it can get to be a problem after 9 pints. finding the bog when you can't stand up is difficult at times.
tell me about it. doctors have tried to kill me off for years with mis-diagnoses. now they wnt to see if covid 19 will kill me. sod 'em. they can keep their witchcraft to themselves.
Is it really that difficult, if there is a dedicated 32amp cooker circuit to a cut out, surely two 13amp sockets off that circuit will solve the problem?
Thankyou, hope it's as easy as that, though the electrician is insisting the double socket the 2 ovens are plugged into is fine. Everyone else says it's not and 2 separate single sockets are required. I understand why. Anyway I'm going to get a different electrician in for a second opinion as there are other potential issues that have also cropped up through this post.
The double socket is not fine, and the metal box it is fitted to is not fine.
I'm convinced that this is a 32A radial circuit, not a 32A RFC, so that is fine.
If the cable going to the socket is 4mm2 and not 2.5mm2, that is fine. The most obvious difference between the two is that the brown and blue in 2.5mm2 are each single copper wires, whereas in 4mm2 they are each made up of several thinner copper wires. If it's 2.5mm2 it needs replacing.
If the cable is suitable, replacing the double socket with two single sockets, mounted onto two 1G surface boxes or one dual surface box will sort the oven connection side of things,
The surface box or boxes should be screwed onto a piece of board, and the cable going into them secured with at least a couple of cable clips.
That brings us on to the round junction box. Was it there before, or did he fit it? It's not he most dangerous thing I've ever seen, but if it is newly fitted, then it is not satisfactory, because there's no provision of strain relief for the cables and needs to be upgraded.
I can't make out if one of the cables is a flex or not? If one is, then this type of junction box is not suitable.
There are junction boxes available that incorporate both cable clamping arrangements and terminals that are suitable for joining solid and flexible wires.
Hello everyone, I'm a new homeowner member and would be really grateful for some advice as I know virtually nothing about electrics. My question/worry involves two single ovens I've just had fitted that the electrician has plugged into a double socket. There is also an isolation switch fitted in the cupboard. I have read that a double socket is good for 20 amps, these two ovens are 2.85kw each and are fitted with 13 amp plugs. Doesn't this add up to 26 amps being used if both ovens are on at the same time? Isn't that a potential fire hazard? Previously in the same place was a slot in double oven cooker wired in with a thick cable. I have also had an induction hob fitted and that has been wired in. I have mentioned my worries to the electrician who tried to explain things to me (went over my head) and ultimately said a double socket is fine. But I'm still unsure and it's niggling me.View attachment 63687 I've attached a photo. Any help would be appreciated. Thankyou
UPDATE!! 13th January
A very big thankyou to everyone. Your advice and suggestions led me to call in another electrician today for a second opinion. As well as the things you highlighted as being wrong, he also picked up on other dangerous issues that weren't visible in the photo e.g. to do with different sized cables being joined, an old joint box being used, amongst other things. He is now going to re do everything as per good practice/current regs - starting by adding another cable from the consumer unit (sorry, probably not the right words) so that if I ever want to I can have both ovens on full pelt and use all the rings on the hob at the same time without blowing the house up... or outcomes to that effect.
So, again gentlemen, thankyou for your patience and guidance, it really is much appreciated ?
Reply to the thread, titled "Hi everyone, new to the Forum, no electrical knowledge" which is posted in UK Electrical Forum on Electricians Forums.
