Hi from a gran with a dodgy socket. | Page 3 | on ElectriciansForums
Discuss Hi from a gran with a dodgy socket. in the The Welcome Forum area at ElectriciansForums.net
Presuming that the plug is now removed...it is up to the landlord to ensure the installation is safe for the next tennant as he is required to have the place inspected/tested
Hi everyone. The offending plug was removed and I have some photos. If I can figure how to put them up! It was the live pin that was burning it looks like it was touching high heat . Fuse is fine and inside the plug looks ok. The socket is slight burning around the live hole. The neutral pin looks green as if it has been damp but was not like that before. Photos won't load, there was a red error message. I have to hand in the key next week and am tempted to superglue a childproof cover to it!
Reply to Hi from a gran with a dodgy socket. in the The Welcome Forum area at ElectriciansForums.net
In the picture of the socket, it looks like one of the neutrals may have been screwed in over the insulation. Therefore, the live may also have...
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
