Hi I’m new here. I’m a non prof DIY er. Having problems with fitting Trendiswitch two way light switch | on ElectriciansForums
Discuss Hi I’m new here. I’m a non prof DIY er. Having problems with fitting Trendiswitch two way light switch in the The Welcome Forum area at ElectriciansForums.net
Welcome to the forum mate.
Are you replacing an existing light switch?
Yes. I did the single one but the double bares no resemblance to the connector on the old fitting
[automerge]1591553249[/automerge]
What’s the problem you’re having with it mate?..
Don’t have a clue where the wires go I forgot to take a picture of the original so now have no lighting
[automerge]1591553386[/automerge]
a mess having seen the pic.
[automerge]1591553866[/automerge]
One brown assuming that’s live. Three black and three grey. Black and grey have little brown sleeves on g tv he end
Looks to me a spiders leg coming from that back box. Please get some body in.
Sorry mate, probably have a good guess from the pics but with out some test gear it’s a bit tricky, and it’s not right for us just to have a shot over the Internet, you need to get a spark I’m afraid mate
if it was a single switch, we would have had a good enough idea to guide you probably.
however what you have there is a modular combination of an intermediate switch and a 2 way switch. (deta)
I am guessing this is located in the hall?
I know some professional sparks that would be scratching there heads trying to work that lot out.
p.s. the original switch (deta printed on it) is different to the new switch and will never work correctly, no matter how you wire it up.
Hello, did you get your problem sorted?
That’s the new switch.
[automerge]1591553464[/automerge]
That’s the original
Then you have bought the wrong switch, one side of the original is an intermediate. This now makes sense with all the conductors in the box. As stated, you need an electrician, 10 minutes tops.
Reply to Hi I’m new here. I’m a non prof DIY er. Having problems with fitting Trendiswitch two way light switch in the The Welcome Forum area at ElectriciansForums.net
M
Hi I’m Julie New to the Forum, but not “New to Plumbing” Hi Friends I’m a Premises Manager responsible for a large Primary School, its actually...
MrsFixit
M
Thanks again for your help, now solved 👍
