hi new to this insaltion resistance test and nvq | on ElectriciansForums
Discuss hi new to this insaltion resistance test and nvq in the The Welcome Forum area at ElectriciansForums.net
L
lawmanxe
Hi just looking through notes can you do an insulation test on a ring main, I have signed up to a course to get my basic starting stuff and want to get my nvq level 3 nearly 30 how can I go about this
Welcome to the forum!
Yes, you NEED to do an IR test on a ring FINAL circuit.
is it that you are asking how to go about the insulation test, or now to go about getting the level 3?
for IR test on a ring final, remove all loads, switch off all FCUs. isolate CU with main switch. remove CU lid. take ring final L and N legs out of terminals. IR at 500v L/E, N/E, L/N.
I started a course can't get my money back so I'm going to complete the course it will give me 17th edition, part p, testing and inspection, pat testing. Where should I go after the course to gain the rest of what I need to be qualified, I know they are changing the nvq so I don't know what to do next and what can I do with the qualifications gained been working with an electrician for a year now already please help I'm struggling with all the jargon on the internet.
If your working with an electrician, ask him to explain what he is doing and why. He should be able to explain loads to you and its easier to learn stuff when you can see it being done etc than from a book or in a classroom
Reply to hi new to this insaltion resistance test and nvq in the The Welcome Forum area at ElectriciansForums.net
  • Solved
An NVQ is a vocational qualification and is based upon your work experience and what you put into your portfolio for your assessor to judge you...
Cheers mate đź‘Ś
