High and Low Voltage Wiring | Page 2 | on ElectriciansForums
Discuss High and Low Voltage Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
cables are not hidden in trunking. trunking is visible and it's obvious use is to carry cables. shirting board is not. how would a new owner, several years down the line, expect cables behind skirting.
It's too late to put sockets in the skirting, they are already in the wall and the walls have all been plastered
[automerge]1567688625[/automerge]
How would future owners know there were cables in the wall, they would also be hidden?
but they are ( or should be) within prescribed zones., where you'd expect them to be. however, plumbers, joiners, and builders have an uncanny knack of finding them with nails or drills, even though the zones are freely available in the internet for anyone who can read. see here. the blue areas are "safe" zones.:
[ElectriciansForums.net] High and Low Voltage Wiring
You need to Google cable zones.
realistically, you know the cables are there. you're not a plumber, so in the real world, it's not too big a deal.
With your Electrical Installation Certificate there should be a page titled Schedule of Inspections, essentially a tick sheet.
On here you should find a comment Segregation/separation of Band I (ELV) and Band II (LV) circuits, and electrical and non-electrical services, if this has been ticked then this claim is incorrect.
Another comment will state Cables concealed under floors, above ceilings or in walls/partitions, adequately protected against damage, again if this has been ticked then this claim is incorrect.
Reply to High and Low Voltage Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Brilliant. Thanks Brian much appreciate the advice.
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
