High CRI GLS bulbs. Not costing a fortune? | on ElectriciansForums
Discuss High CRI GLS bulbs. Not costing a fortune? in the Lighting Forum area at ElectriciansForums.net
1Justin
Surrey
Does anyone source reliable and good value high CRI led bulbs in standard GLS format (ES & BC)? - Ones which don't cost a fortune and give out good ~2700..3000K light?
I have found that the fairly easily available and not too pricey Philips CRI97 "ExpertColour" GU10's make a really noticeable improvement. I get them in for customers when it matters and they do make colours pop out. However, replicating this with GLS seems to suddenly get super-expensive (Soraa brand for example ÂŁ25 each!).
I fit for myself, and tend to provide for most of my customers, budget-brand LED GLS because few want to spend on light bulbs. I often use just the LAP ones. - But they often make everything look a bit crummy and greyed out. I think standard that standard Philips GLS bulbs are a little better, but not startlingly good. - Pull up a CRI 97 lamp alongside though, and the difference can be startling.
Reply to High CRI GLS bulbs. Not costing a fortune? in the Lighting Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
