I need to source a high IP rated 3-5 way board. However, Everytime I search they all come back plastic which obviously isn't compliant with current regs.
The area I have to work with is too small to fit a small board inside an enclosure so thats no option.
The environment that the board will be in is suseptable to small amounts of condensation and sometimes maybe small drops of water from above.
The board is a sub board and is for lighting within a lift shaft/plant room area.
Any ideas if metal consumer units IP54, IP55, IP56 rated are available?
