high reading | on ElectriciansForums
Discuss high reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sparkies2306
Hi guys,
Was doing a bit of testing on a new house today i was doing a test on mains on a tncs system or pme for short
the regs states reading can be a max 0.35 when i done the test i was gettinmg 0.41 have checked all supplies and earth to make sure of good connections but all is ok
would anyone have any sugestions on how to get this down the supply to house seems to be coming a fair distance to house as its out in the country would this have any bearing on it
any help appreciated
Hi guys,
Which Regs. state that the max reading is 0.35?
As far as I'm aware, guidlines suggest the max resistance should be 0.35, nothing states that it must be.
If you were to inform the DNO, that the reading is 0.41, they would probably take no action, and will inform you that the 0,35 is just a guidline.
apologies spinlondon i did mean resistance i understand what your saying but just wanted to put it out there to see what others think to be honest i have never had as high a result on a pme job before so wanted to check with you guys
i ave an inspection next week with niceic and a very fussy inspector its something he will look at
cheers
The high reading could be down to a poor PME connection somewhere on the network, or it could be just that the installation is a long way from the supply.
However, it could also be due to an incorrectly calibrated meter, or even poor connection of probes/terminals.
I would suggest that you report the situation to the DNO, but as I posted earlier, be prepared for them to fob you off.
Make sure you have got really good connections with your leads, it is easy to drop a bit of resistance into the mix if your probes aren't pushed fully on to the leads etc. Been there, done it, and got the red face when YEDL eng came out for nothing! I wont elaborate except to say it had something to do with the aftermath of a night on the ale, and fused test leads........you can work out the rest for yourselves.:oops:
Cheers.........Howard
It's impedance as it's a live test.
I'd be surprised if you can null leads on a Zs/Ze test, I've never seen a tester with this option.
All leads were perfect and once i got the reading nulling my leads was the first thing i done. originally it was 0.43 went down to 0.41 using the fluke 1653b all in tester
and i think i agree with spinlondon the instalation is along way from the supply which is why i thought may be the high reading
thanks for help guys and advice
I've been a Megger man for so long now I forget other manufacturers exist, I live and learn!
always had megger, starting with the wind up model, circa 1970. used to be called an apprentice alarm clock.
Reply to high reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
I don't think it will work with only one stake unless some meters have different operating parameters. It doesn't necessarily have to be a stake...
