high resistance joint? | on ElectriciansForums
Discuss high resistance joint? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stumas
what is a high resistance joint? and how would you test for one?
im thinking a loose conection could this be right?
A loose connection may give an high resistance, also a corroded conductor at the joint
If a current is passed through a resistance then heat is generated in the process
If a large current is passed through a high resistance joint,then a lot of heat may be generated
The higher the temperature the higher the resistance becomes,then the higher the resistance the higher the
temperature and so on
You may be able to test for this high resistance with a thermal imaging device when the circuit is loaded
You may be able to continuity test the conductors for an expected resistance value and compare the results with a low reading ohmeter
Reply to high resistance joint? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
How many and what type of cables do you want to join, Chocbox is the last thing I would use.
