High ze and circuit zs ???? | on ElectriciansForums
Discuss High ze and circuit zs ???? in the Australia area at ElectriciansForums.net
Urgent advice please.
I have done a consumer unit change where the main earth is 10mm and meter tails are 16mm.
I have connected new 25mm tails on consumer side of isolator switch and 16mm main earth to single pole block onto DNO 10mm earth.
Problem I have is a Ze of 0.54 and PSCC of 10KA. Is this something I can correct or is it a DNO problem?
Zs on all circuits is within limit except oven circuit which is 1.52 against max permitted 1.44.
Obviously will come down if Ze does.
can you lower the breaker at all?
Not sure of the cooker rating. Very old free standing unit.
6mm T/E used from 32A breaker and cooker switch has a socket.
Would lowering to 16A create tripping problems ??
Long term the Client has sumitted plans to extend property and the kitchen will be moved with new circuits and appliances.
depending on make of board, you can order 25 amp MCB,s, alternatively if you cant get one to fit the board you could put an enclosure next to the consumer unit and down rate it slightly, that is if the cokker loading allows
Well, if you go by the regs then you would be ok as the CU you have just installed will have full RCD protection, which allows 1667 ohms.
Thanks Jason.
17th ed high integrity cu fitted.
With the intended plans to extend and relocate kitchen etc. Is it enough to just comment on the high reading on the cert and leave it at that. ?
An additional enclosure next to cu not really an option as just fitted 17th ed high integrity 15 way board to allow for all future build plans on property at client request to avoid all seperate enclosures and add ons etc. Do wylex do 25A
Thanks Jason.
Yes you can and i expect you will need to include the cost of a new radial for the cooker when the other works are being done.
Reply to High ze and circuit zs ???? in the Australia area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
