I
Innominata
Hi Guys,
I have recently changed the CU in my home in order to have a Napit inspection (not yet a member).I have done a Zs check on all the sockets. Most of the readings are ok but a couple are reading in the region of 1.30 to 1.39 ohms.The MCB is a 32 amp B type.The max allowed from 7671 is 1.44 but do I have to use the 80% rule which would bring the max down to 1.15.The new board is a split load with dual RCD.
many thanks
many thanks
