higher Zs with RCD | Page 2 | on ElectriciansForums
Discuss higher Zs with RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Know what your saying tel, but every time I check on each side of the RCD, its down to the non trip test setting that causes it.
Reply to higher Zs with RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
What readings were you expecting for the cable prior to testing? What is the make of the protective device? Is there any previous paperwork [test...
