Hive Active Heating 2 Wiring HELP | on ElectriciansForums
Discuss Hive Active Heating 2 Wiring HELP in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
D17XFD
Glasgow
Hello,
Ive been reading through these forums and thought id post to ask for help. I have the hive active 2 and am a bit stuck. attached is the have backplate which i need to wire but also below is my boiler thermostat wiring.
1, 2 and 3 on the backplate are common heating off and heating on but the problem is i only have two thermostat wires... I am at a loose end, can anyone help?
[ElectriciansForums.net] Hive Active Heating 2 Wiring HELP
Fitting the hive is going to require both 240V and 24V connections to be made to the backplate. I recommend that you have a competent electrician fit this for you as this requires extra care to avoid a dangerous accident.
Reply to Hive Active Heating 2 Wiring HELP in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
Hive thermostat multizone help Can anyone help me. I have just moved house and we have a boiler with a separate hot water tank and then 2...
Rick1980
R
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
