Hive underfloor heating fitted incorrectly...? | on ElectriciansForums
Discuss Hive underfloor heating fitted incorrectly...? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Spengler
London
I have two hive zones. One for the house and one for the UFH in the kitchen.
When I boost the UFH from the thermostat or the Hive app the light on the Hive receiver comes on immediately, but the boiler does not fire and the valve triggering the UFH does not move. Basically nothing happens.
However, if I do the above and also boost the other Hive zone (in the hallway), straight away the valve opens, the pump starts and the UFH comes on immediately.
For this reason I think UFH receiver is wired incorrectly as it can't call for heat directly.
Can anyone see if it has been wired correctly? Cheers!
[ElectriciansForums.net] Hive underfloor heating fitted incorrectly...?
TL;DR
Hive underfloor heating wired incorrectly as will not call for heat separately to other zone.
Assuming you have 2-port valves, the switched live power to the boiler emanates from a microswitch in the 2-port (orange wire).
The wiring from the receiver seems right from what I can see.
Sorry edited this after further consideration!
It's possible the fault is to do with the underfloor 2-port rather than the wiring
Has it ever worked to your knowledge?
Reply to Hive underfloor heating fitted incorrectly...? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
3 core wouldn't, but 3 core and earth should I think. The live from the UH4 could feed both the brown and grey of the valve.
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
