HMO Room Wiring | Page 2 | on ElectriciansForums
Discuss HMO Room Wiring in the UK Electrical Forum area at ElectriciansForums.net
mineral
London
I am planning to create a 6 bedroom HMO , to be leased to the local council (Short term lets). Their surveyor has said that each room needs to have its own consumer unit. ie Only one room will trip if there is fault
Has anybody got experience of this or done this ? I have asked a electrician and he said it is not required or unachievable to have 6 CU's and 1 for communal area's.
It is achievable to have consumer units in each room. However, you may well require an AFDD and possible SPD costing hundreds for each consumer unit. For this reason it would be better to have one central consumer unit supplying each flat with possibly a din rail meter for each flat. For instance one landlord I recently did some conversion work for had a bill for ÂŁ6000 electricity. The tenants were wont to leave heaters on and disappear off to sunnier climbs for a few months. At least you could switch off the supply from a central location if needs be if you can't enter the room. Tenants can be most interesting in the way they treat property and equipment. It may therefore be safer to have the consumer units in a central location.
If the Local Council, who will be leasing the HMO have stipulated each room must have it's own C.U, then each room must have it's C.U. or go find someone else to lease it to.
Any discussion about alternative ways of doing it is pointless.
It doesn't matter whether it's unusual or over the top or if other extra work needs to be done as a result.
If the Council wanted 2 rooms painted Blue, 2 Pink and 2 neutral colour, then that's what they'd need to be.
If the first electrician has said it's not required or unachievable to have 6 CU's and 1 for communal area's, then the O.P will have to find one that can achieve it.
You might be retired with a pension but others are still trying to earn a living and can't afford to design for Free.
What's this all about?
[automerge]1581844465[/automerge]
OK Good luck
What you will do it for free?
I certainly wouldn't, do it for free that is.
Why would you want one in each CU?
Reply to HMO Room Wiring in the UK Electrical Forum area at ElectriciansForums.net
I would think that if they are apartments, and not something like uni halls with private bedroom and communal facilities, then each one would be...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
