Hob\Oven wired wrong way round? | on ElectriciansForums
Discuss Hob\Oven wired wrong way round? in the UK Electrical Forum area at ElectriciansForums.net
alexp
newbury
Hi,
I'm thinking of replacing my 8 gang switches which are all 20Amp DP to newer MK ones. One of them is marked "Hob" but actually controls the oven. The switch on the other side of the kitchen near the Hob and cooker actually controls the Hob. I think this is a 45Amp style switch. This is how it's always been since I moved in. Should these be round the other way and the large single switch control the oven and the gang switch control the Hob as labelled?
Regards
Reply to Hob\Oven wired wrong way round? in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Obviously not a building/DIY forum so will keep it short but yes - we've taken all the floors up. Several joists in the bathroom need doing as...
