Hole saw recommendations | Page 2 | on ElectriciansForums
Discuss Hole saw recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Hey,
Any other quick release arbor systems out there (apart from the Mandrex and Bosch)?
Cheers
for downlights, a full set of 6 with a common arbour is < £10. for serious work, Srarret or Dart.
Yeah those quadsaws are cool but a bit expensive.
Snooping around I came across these:
Triton Multi-Tool Socket Backbox Cutter
[ElectriciansForums.net] Hole saw recommendations
Not doing enough 2'nd fix to buy one but I am tempted to try it out.
waste of space.
If you look at it theres no way that can actually even work ;)
I was thinking the same but then I found this on youtube:
Gtranted, this one is a bit of a different design then the earlier one but... seems to work. Althought the bit about 'not hurting the technicians' at the very end is hilariouse XD
.....it's only a matter of a couple more posts,before you're gonna get the "hammer & bolster" advice... :neutral:
Those box shaped cutters look absolute tosh. It takes about 20 seconds to cut one out with a straight multitool blade. How many seconds do you need to save per box, is the job that time critical, are you doing that many boxes it would make a difference ?
Using multitool blades in plasterboard ruins them pretty quickly anyway so you're going to need a constant supply if doing a lot with them. You'll need a single and a double which is about £20 combined. I use one of my sub £2 wood bits that is on the way out. Much cheaper.
Sure, strictly plasterboards usage.
But if already on the topic, any tools or technique you would recommend for brickwork?
for brick, i stitch drill with a 7mm or 8mm sds bit, then whack in a sds scutch chisel.
Reply to Hole saw recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
The last ICS I fitted hadn’t been registered when it left their factory… so just got a “device not recognised” error. Helpline fixed it over the...
