holesaws? | Page 2 | on ElectriciansForums
Discuss holesaws? in the Electrical Tools and Products area at ElectriciansForums.net
I find the Bosch ones are quick and easy to use but they do jangle around in the arbor to much and accuracy suffers. I only ever use starrett tried and tested would never use anything else.
I got my last 2 sets from Aldi, about a fiver a set, had them years now and still going strong, sharp as the day i got them, no problems going through steel enclosures or plaster etc. I do have the odd starett ones for the sizes not in the Aldi set, and to be honest they dont perform any better.
Cheers...........Howard
Crikey....I'm off to Aldi then....
I do find that a step cutter can sometimes be easier for putting 20/25mm holes in panels for conduit. As someone else mentioned the Bosch PowerChange ones are a tad sloppy at times.
been using Bosch PowerChange for ages I rate them as I have put them through hell and they are still going strong. I like the fact you can quick change the pilot drill as well as the hole saw itself. (Have snapped one going through a steel bath):donatello:
Reply to holesaws? in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
Use THWN if it might get wet. These wires are not sunlight (UV) resistant unless marked as such. If it was for mains voltage I gather it wouldn't...
