Holiday let Fire Alarm | Page 2 | on ElectriciansForums
Discuss Holiday let Fire Alarm in the UK Electrical Forum area at ElectriciansForums.net
EddieB
Now there's a requirement for a Fire detection in all bedrooms as well as hallways Lounge and Kitchens can the detectors be wired from the existing lighting circuit or must it be a dedicated circuit, I know what's best practice but the logistics make it very expensive and impractical
Here in bonnie Scotland, Aico 10 year li battery smokes and heats, radio interlinked...there is no simpler system.
No redecoration, no raggling (chasing)of walls and ceilings, plastering, painting...
Just stick 'em up, pair them, walk away...I have never had a call-back on Aico yet.
OK, it's a very fast installation, so not a lot of money to be made, but the clients love them once you have sold the concept...especially the quick in and out and no other trades to make good. An extra ÂŁ200, against about 3 times that for making good for hard wired...and it leads to extra work from satisfied clients.
I like the sound of this believe me but I'm. not. sure if it's. BS 5839 Part 6 Grade D1 Category LD1 compliant if it is sign me up
In the USA all smoke detectors are required to have their own circuit and be wired together so if 1 goes off they all go off.
Do these still need a mains supply, if so it might not always be so simple.
If not then radio interlinked wont last anywhere near 10 years despite any claims otherwise. 1 year maybe, 10 years no way hosea.
This is allowed in the UK but it is preferred to supply them from a regularly used lighting circuit. This way ensures that if the circuit trips it will be noticed quickly.
Also we are allowed to use radio linked alarms or have them wired together.
Years ago I would have agreed on the battery issue.
Now the batteries and the alarm technology are much better, however I would not install something like Fire Angel (they had a product recall a few years ago as 10 year batteries lasted 1.5 years)
On the other side I install Aico battery interlinked alarms and have had almost no failures, the failure rate is less than 0.05% (we have installed lots), we tend to get the client to buy them direct from the wholesaler to keep our turnover down
Thanks James
I believe that the original question would have negated most of your need to display your knowledge on Fire Alarm systems, however thank you for your manufacturer recommendations
Hi, baldelectrician doesn't BS 5839 Part 6 Grade D1 Category LD1 compliant regs want mains powered units as opposed to all battery which falls into the BS 5839 Part 6 Grade F1 compliant regs?
I think you’re mixing me up with someone else, I made no manufactures recommendations.
only made a point about definitions
Ok… I’ll bite.
Oscar… are you suggesting that aico, with a 10 year battery, no mains power will not last 10 years because of the rf functionality?
I would estimate 50% of Scottish homes have at least one of these types of detector since the new legislation came in. Possibly more.
Are we certain OP is in Scotland, or was that just to explain something?
If they are, then all domestic properties are the same whether owned, rented or holiday accommodation… it’s one smoke on each hall/ landing…. Heat in kitchen and smoke in “a room that gets used the most” like a living room.
Extra detectors can be put in if required according to layout of house.
However, some of my English customers just over the border have indeed needed detectors in bedrooms for holiday lets.
Ah you have used FireAngel then?
I would say that if you were doing a rewire than putting in the mains powered Aico would be better as the alarm modules are cheaper, more so when it comes to the ~10 year replacement due to sensor age, etc. I would still use the light circuit for powering it though unless something complicated where it had to be separate.
Best thing to me about the Aico range is the remote test/silence button, saves folks trying to wave a towel at them, etc.
Ok… I’ll bite.
WHAT!!! you coming over the Border ...... Hahahaha!!
Yeah. Got my passport and a strip search every time….
The border is only 4 or 5 miles away from me… my wholesalers and nearest supermarkets are all on the English side.
Handy this time of year when scotland has minimum pricing on alcohol.
Reply to Holiday let Fire Alarm in the UK Electrical Forum area at ElectriciansForums.net
I've looked at the fire assessment from the last HMO I did for the same landlord and fire assessor, the risk assessment is pretty worthless, it's...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
