Home extention ideas | on ElectriciansForums
Discuss Home extention ideas in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
Hi All,
Happy new year to all!
I'm due to have an extention built early this year, the extention is a two story side, single story to the rear, including a new patio. The extention will have a kitchen diner, utility, toilet, garage, salon space (wife to work from home) and bedroom ensuit.
I'm starting to think about what to include to future proof, along with any out of the box ideas. With the wealth of experience in the forum I'd appreciate the forums advice.
Fire away!
Thanks!
Low level lighting in the en-suite on a sensor so turns on when you go in for a whizz during the night, Bluetooth speaker, mirror with demister pad, wifi booster, Internet points at TV position, Phillips hue lamps in selected locations, smart heating controls, electric blinds, 2 way switching at bedsides
Hi Lee,
Thanks for your response, some great ideas! Any thoughts on external lighting and kitchen lighting and kitchen additions?
you forgot the wet bar with hand pulled ales and a row of optics.
Hi Lee,
If you use hue lamps on any outside lighting then you can use the geolocation on the app so they come on when your a certain distance from the house. I would avoid any fitting that goes in the ground. Under cupboard lighting using LED strip, down lights set 600-700mm/at edge of worktop to avoid shadows. Cupboard door switches on any larder cupboards so lights comes on when you open doors. Instant boiling water tap. Put in an RCBO board.
Reply to Home extention ideas in the UK Electrical Forum area at ElectriciansForums.net
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
