Home made HaPanels showing Volts but no s/c amps | on ElectriciansForums
Discuss Home made HaPanels showing Volts but no s/c amps in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
Gshep
Having made a couple of 150*150 by 36 Panels one is showing volts but no S/C Amps
Re: Home made Panels showing Volts but no s/c amps
interesting wonder where that HaPanel came from.
UNI-T UT50A MULTIMETER
VOLTS --- LEADS INTO RED VOHMS BLACK Com 200v DC Live connection from from panel Negative connection from panel
AMPS ---- LEADS INTO RED 20A max BLACK Com 20A DC Live connection from from panel Negative connection from panel
Weather ----- OVERCAST One panel reading 17v .25amp
Kind regards George
Hold on a minute are you connecting the meter across the pos and neg outputs from the panel when trying to measure current? If so you need to be in series with the panel and the load,at least thats how it's done with other electrics,pos from panel to pos on meter neg on meter to load,neg on panel to load,otherwise you are going to fry something.
To get an Isc (short circuit current) reading, you will need a clamp meter. The positive and negative leads need to be plugged/connected together and then a reading can be taken.
well this is the way I was shown? Have just done another test on the aforementioned panel, as the sun is out, and now it reads 2.4 A Meter NOT FRIED.
at 69 I am still willing to learn something new even though I spent 53 years as an electrician and PARTLY working with DC be it on LARGE ELECTRICAL MACHINES
Regards George
yes I was saying that, what I was showing that on a good panel I WAS getting amps.
So lets recap
So good panel getting Volts and Amps
what I consider a bad panel getting Volts but no Amps
as it only takes me a few hours to strip a panel what I intend to do is carry out a wee experiment
Staring with first cell and 500w halogen lamp check Volts and existence of amps.
Just had a thought I have couple SPARE cells will prove the feasibility of this idea first.
I would imagine that if you only deal with Manufactured panels you will not have come across this problem
I have Manufactured and home made
Manufactured are Grid tied
Home made Panels are on my own off grid system
Will let you know what I find
Being interested in solar, retired and 69 I decided to do the NICEIC Certification Course and received the Certificate of Competence on 31/01/13
Kind Regards George
ok did the test on one single cell resuts below
250w halogen lamp placed at 1 meter above cell
.56 volts
.36 amps
will now strip a panel and check all cells
George
I have been checking panels as I found a duff one. So be interesting to find out what is stopping the amps. My panel (not home made) is showing correct voc and correct isc but put it under load and the imp is only less than 50% of design so where is it breaking down? Never seen this before and no obvious outward signs. It just refuses to produce the goods.
As mine is home made and easy to strip down will let you know what I find might be a few weeks before I cab do this as I am busy with another project WOOD TURNING .
Reply to Home made HaPanels showing Volts but no s/c amps in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
