Homework task. | on ElectriciansForums
Discuss Homework task. in the Electrical Course Trainees Only area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
Ok folks. Been given some homework to detail the process you would follow to wire up a loft conversion. The suggestion is the an additional CU is added to feed a 10kw shower and splitting the tails to feed. What's the correct process to follow when disconnecting the main CU, pulling the main fuse and notification / dealings with DNO.
https://www.dcusa.co.uk/Documents/De-Energisation - FAQ Document v 1 0.pdf#search=de-energisationj
DCUSA is the distribution connection and use of system agreement.
Reply to Homework task. in the Electrical Course Trainees Only area at ElectriciansForums.net
