Honeywell / ADE - Optima and Remote KeyPad | Page 2 | on ElectriciansForums
Discuss Honeywell / ADE - Optima and Remote KeyPad in the UK Electrical Forum area at ElectriciansForums.net
North West UK
Hi I have just installed a Optima G4 panel and connected up to a remote Keypad. The alarm works ok however the RKP is displaying the "System Optima G4, Software installed and Build number". I guess l have to activate this. How do you enable the Remote key pad (RKP) from the panel or get this functioning. In the engineers manual it only talk about activating the PA on the RKP. Help would be appreciated
no the panel has its own nvm, so user codes stay programmed....all the keypad can do is basic panel code changes and programming which is stored on panel......all text and banner programming is stored on keypad memory. So basically you will loose zone texts etc....but codes remain, unless you nvm reset the main panel
Reply to Honeywell / ADE - Optima and Remote KeyPad in the UK Electrical Forum area at ElectriciansForums.net
