Honeywell galaxy 2-12 master | on ElectriciansForums
Discuss Honeywell galaxy 2-12 master in the UK Electrical Forum area at ElectriciansForums.net
Brighton
Hello people I have a adt non monitored system I am after the master code and engineer code
Mine is playing about and the ex adt guy I have lost his number so can't get hold of him
and yes I know that no one is going to post on an open forum so if someone could help message me thanks
and it's not the default codes I need it's adt ones I think
Having been converted to fibre optic from copper telephone as everyone has to soon I have a comms fault message that requires engineer access for a permanent removal ……. but I only have the manager code .
ADT tell me they cannot supply the engineer code as they no longer hold records .
Local installers tell me they cannot obtain it or by pass the fault or even replace the control panel. They tell me my system is now totally defunct.
I have however found a by pass fix .
Type in your manager code .
Then hit
A … ENT …. ENT …. A … A … ENT
Your alarm is then on full set and working .
Unfortunately without an engineers code you will have to do this every time you want to set it. .
10 keys to hit instead or 1 but you haven’t needed to scrap your alarm !
Then hit
Reply to Honeywell galaxy 2-12 master in the UK Electrical Forum area at ElectriciansForums.net
