Honeywell Thermostat Upgrade
That is not my understanding - that may well be wrong.
It has batteries exactly the same as the CM900
And it simply fits in place using the back plate of the cm900.
So far a dial stats go - my experience is the lag - hit 24 - then hope to remain at that - then wait until it hits 19 before it kicks in
I would advise against that one, I've removed a fair few of them for people who get thoroughly irritated with them not being simple to operate, one which has a simple dial to set the temperature is always far more popular.
Indeed, pressing the up arrow button to increase the temperature and the down to lower the set temperature such an irritation.
Why -
Every rad has a TRV.
That aside -
Why would I want a cold Hallway to to determine the whole Bungalow temp!
Just asking,,,,,,,,,,,,,
Hum.... You don't heat the hall to the normal room temperature. It's usually a couple of degrees lower
I find a lot of people cant get their head around the programming of these as they don't have on and off periods just different temperature set points.
The transmitter unit has batteries yes, but the receiver requires a permanent live supply.
Would you like me to type this a few more times?
You don't have to take my word for it, I only work on 3/4 domestic boiler control circuits each week, most of them having wireless stats fitted these days. It's not like I know what I'm doing!
The presence of a dial does not affect the lag (hysteresis) of the stat, that is a product of how the stat works. A mechanical stat will have greater lag than an electronic one. Electronic dial stats are available, such as the Drayton digistat or digistat RF which are as accurate.
Having a TRV in the room where the roomstat is will break the control feedback loop so the system will not perform correctly
Sorry Sir -
I do not have the experience to debate with you - you win.
As it stands at the moment -
I have a CM900 - fitted with Batteries - that does exactly as intended - namely it has only 2 wires connected; and it controls the temp like a dream. EXCEPT her indoors wants to control the temp at lounge level. (Who am I to argue about any logic).
So - it seems to me; that if as advertised; I can replace the current unit (again with batteries) and advertised as a 2 wire connection (again exactly as what I have) with a unit that sits on the Hallway wall - but gives a wireless unit to control from the lounge or wherever - seems an answer??????
Honeywell DT92E1000 RF Digital Room Thermostat: Amazon.co.uk: DIY & Tools
Sorry Sir -
If if and I say if you decide to control your heating by the temperature of the lounge you better leave the doors open or else you may well have a very cold house
Sorry Sir -
For which the installation instructions here http://www.honeywelluk.com/Documents/Installation-Guide/pdf/1075.pdf clearly state that a 230V live supply so required for and all of the wiring diagrams indicate that a permanent live and neutral plus the two switch wires (one in, one out) are required for the receiver unit (BDR92 relay box) along with absolutely no mention of battery power.
Shall I say it again?
I, like many people here, have fitted a lot of these things and have a bit of a clue about what is required.
The receiver requires a permanent live connection which will not be present at your existing thermostats position.
Nothing complicated about that either, but some folks find crossing the road troublesome.
Compared to turning a dial up and down it is nowhere near as easy.
I'm all in favour of modern technology and gadgets, but when it comes to heating and lighting I want a switch I can turn on for on and off for off. And a lot of people out there agree.
Now going a step further and fitting something like a nest or hive I can fully appreciate as it actually seems to be a good system and gives you the ability to turn it on and off before you get home and actually have a warm house when you want it.
